Versa Oil
ghrshow
Car: 2008 sedan s
Hi what type of oil does the car take?
synthetic or old school?
Does Nissan recommend 3k or 5K?
Thanks, GHR
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
1) For what is reccommended, please read your owner's manual.
2) For oil... I used the search button and searched for "oil" in the Versa forum and came up with the following threads:
zerothread?id=299314http://forums.nicoc ... ?id=273198
And many, many more. But you get the point.
ghrshow
Car: 2008 sedan s
1. I dont have the car yet , so No manual yet!
2. when I searched the forum i got results for the whole damn Nico site! Not useful.
Thanks for the links.
GHR
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
It will take any oil that meets the manufacturers specifications.
Ever Victorious
'73 AMC Hornet
If you got search results from the whole forum, then you did not select a forum to search. When I did my results, I selected only the Versa forum in the drop-down menu.
Just FYI.
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
I've been running Mobile 5W-30 conventional oil. Hasn't seized yet!
(for those of you in New York, NY, I use "Fitty Dubya Tritty, O'Skoo").
bluev
Car: 87 Nissan Sentra Sport Coupe XE
I just started running MOTUL 300V Full Synthetic 5w40. I have 18,700 miles.
keanucosmo
I use Mobil 1 5W30 Synthetic.
Superdave54
Car: 2008 Nissan Rogue
The recommended oil for the Versa and the Rogue is 5W-30, with an API SM rating. The SM rating is important. Not all oils meet that spec. I would strongly suggest you shy away from any other "weights" than 5W-30.
Rockhound
Car: 2007 Nissan Versa 1.8 SL HB CVT
2008 Mazda3 GT
And...
Aside from some high-performance engines where synthetic is required, synthetic and 'conventional' can be used interchangeably in just about every modern car. Even from oil change to change. They can even be mixed. Claims otherwise are usually the result of synthetic oil myths that have persisted for several decades.
Anyway, I use Mobil 1 full synth on my cars.
BBISHOPPCM
Mobil Clean (dino) oil is an SM rated oil.
sigjam
Car: 2007 nissan versa
I use Valvoline 5w30 old school.
