Versa Oil Change intervals
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
versa09guy
Hey guys, I was wondering how often you change your oil. Ive got the 1.8 engine, do a 60/40 mix of highway/city. Car has 3K miles on it, just switched to 5W-30 Mobil 1 synthetic with a mobil 1 filter. I was wondering if 6 months/7500 miles is a reasonable change interval, or if i should change it earlier. Will the oil filter last 7500 miles, or should I be changing it more often than that. Thanks for the help!
soros151
Car: Nissan Versa 09 Hatchback / Toyota Camry 95 Coupe
What do you use your car for? Just going to work, or part of work? Weekend fun? After you decide, you can do one of 2 choices. Follow the manual and do it to theirintervals, or if its under heavy use do it sooner. If the manual says something like 5000 miles, and you only use it to go to work, then do the 5000 miles, if you have fun with your car on the weekends at the track or something like that, then you would have to do it sooner. In my opinion I wouldn't use the oil all the way to 7500 miles. That filter blocks finer micron particles, it would take less to clog it up.
NODES
Car: 2007 Nissan Versa SL (Blue)
I do mine every 3000 miles, ordinary driving.
I actually did mine today
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
NODES wrote:I do mine every 3000 miles, ordinary driving.
I'm with Nodes.
1st change 1500, 2nd 3000. From here on 3K changes with Wix or OEM filters. I am going to use regular oil. I will save the good synthetic for my other cars.
blindsnyper
Car: 2007 versa
i use castrol syntec 5w-30. i change it every 5000 miles (after changing it every 3000 miles until about 15000 miles) and i dont worry about time between changes. and i use a k&n filter.
led hed
Car: 2009 Nissan Versa SL HB 6spd
my dealer had me come in at 6000 kms. dino oil.i won't change to synthetic until around 10000 kms.
Return to “Versa Technical Discussions”
