robaustin wrote:There is another thread on here about the iPhone - apparently anything past the first generation iPhone will work with the music interface, but the iPod interface will not charge the iPhone anymore. This is due to Apple's 3.0 software upgrade.
As for using the controls on the radio for the iPod functionality - I have an iPod Touch - essentially the same as the iPhone.
The controls are good. Not great, but good. You can maneuver to playlists (and even the Podcasts section - to my happy surprise) - you can play them in order, or set them to shuffle. Once you learn the controls it's pretty easy. The only thing is that the radio only has a one line display, so you have to push the DISP button to cycle through the Artist, Song etc... on the track that is playing. Also - there is no indicator showing the length of the track.
It's a good basic setup to control the iPod, and it works. I like having my iPod hidden away in the top compartment.
So beware the non-charging - that COULD be a problem if you take a long trip - in which case you might be better off having the iPhone on a window or vent mount, plugged into the AUX port with a charging cable run to the power jack in the center console.
--*Rob
Jaibroken Devices allow an app that cost 2$ on cydia store to charge with whatever cable you buy even on firmware 3.X
I own a 3gs, Audio call/transmission and reception are working great; just don't forget that that kind of reception is Mono and NOT stereo. This is a sad reality with bluetooth handset protocol. Same thing for Iphone 3G model.
Now,Iphone 3g and iphone 3gs has Bluetooth Stereo capability while streaming music over any A2DP Bluetooth receiver; the receiver on the versa doesn't support AD2P and will never do. That's why I installed a receiver that allows that ;-) See my other thread concerning AVN726e installation.
Cheers
