Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Tue Jan 08, 2008 1:45 pm
Nissan says don't put your cellphone in the SAME POCKET as your iKey, as it CAN cause the iKey to scramble and not function. (only confirmed on the Altima)
The symptoms you describe are NOT the same as an iKey malfunction.
If your iKey gets scrambled or malfunctions, the car won't even turn over, or for that matter, unlock with the iKey. It will work fine with the physical key.
I agree, your problem is the fuel pump. The fact that it worked fine with your physical key is irrelevant, it was just a coincidence.
