Versa Hatchback hatch rattling over rough roads.
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
aricbeemer
Lake Manawa couldn't find anything wrong with the hatch. But it rattles and creaks going uphill or hitting rough roads. I have been in the back seat and saw that the hatch moves back and forth allmost like its loose but looking at the latch its hard to tell what is wrong. Any help is appreciated!!!
aricbeemer
Anyone?
williamk10
Car: '07 Nissan Versa SL
get someone to drive while you're in the backseat facing the hatch door and feel your way to the sound.
Mine rattles like crazy. I actually took off all the panels last night in order to find it. I also took off the covers for the rear strut tower as they were loose and could vibrate while going over small bumps. i'll let you know if that solved anything
aricbeemer
williamk10 wrote:get someone to drive while you're in the backseat facing the hatch door and feel your way to the sound.
Thank you so much!! Um do you think White Lithium Grease would help if I sprayed it over the latch???
williamk10
possibly.
If you're hatch door is moving so much, this might be a stupid question but are you closing it allt he way in? If you close it half way, it'll latch on but you will get a lot of play (about an inch)
iluvmyVersa08
Car: 2008 Nissan Versa SL Sport
Mine only rattled within the first couple of weeks of ownership. After that, no rattle.
The only rattle I do hear, is my sunglasses in the sunglass compartment beside the map lights. Other than that, no rattles with the V.
NODES
Car: 2007 Nissan Versa SL (Blue)
iluvmyVersa08 wrote:Mine only rattled within the first couple of weeks of ownership. After that, no rattle.
Ontario roads are 10 times better then what they call roads here in B.C
aricbeemer
Trust me its shut but it still manages to creak and sound like its not shut.
NODES
only way to find the creek is to get in the back like WilliamK said and listen for it and go from there, it really is a trial and error process.
NODES
I just started to get the same creek in the back, I sat there for a good 2KM but I cannot pinpoint it.
It does sound like the hatch is open, yet everything is tight.
What pisses me off is you fix one creek another takes its place somewhere else.
NODES
anything new to report?
williamk10
No, it still does it. I can't find it. However, I did find some metal shavings from when I had to drill holes on top of the hatch to install the OEM spoiler. There could be a bigger chunk of metal hiding in the hatch somewhere, buzzing around as I go over bumps.
I think we can all conclude the only way to get rid of the hatch rattle is to buy a CF hatch.
NODES
williamk10 wrote:No, it still does it. I can't find it. However, I did find some metal shavings from when I had to drill holes on top of the hatch to install the OEM spoiler. There could be a bigger chunk of metal hiding in the hatch somewhere, buzzing around as I go over bumps.
well that is not what I wanted to hear
I will find it, taking the hatch apart today.
nimda
Car: 88 Honda CRX, 07 Versa
I live in Omaha, and me and the wife own a versa. I don't drive it... she does... anyways, I have over 50 Sq feet of dynamat in the back hatch area of mine, it made the car A LOT quiter, but the plastic rattle was still there.... (that's not why I put dynamatt in anyways) BUT... I took a scrap piece of automotive carpet, and put a little RTV sealant on it, smear it in a bit... and then tuck it between the plastic and the metal on the inside of the hatch. That helped A LOT...
NODES
nimda wrote:I live in Omaha, and me and the wife own a versa. I don't drive it... she does... anyways, I have over 50 Sq feet of dynamat in the back hatch area of mine, it made the car A LOT quiter, but the plastic rattle was still there.... (that's not why I put dynamatt in anyways) BUT... I took a scrap piece of automotive carpet, and put a little RTV sealant on it, smear it in a bit... and then tuck it between the plastic and the metal on the inside of the hatch. That helped A LOT...
lol I did the same thing but used rubber grommets a few nights ago, was driving me crazy...fixed my rattles in the back.
Return to “Versa Technical Discussions”
