amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Sat Nov 03, 2018 12:55 pm
There are several two piece push-in 'one first then the center goes in later to fasten the part' used there. Part C105 in service manual.
6 holes in front of valance and 5 in back, the back edge has 1 in the center but front side has 3 on each side but none in center. The back 5 appear to be small bolts or screws. Front uses push pins mentioned.
That on an '11 which should be about the same.
That stuff gets changed all the time depending on what box of fasteners is on the assembly line at the time. They use more than one vendor to keep the lines full of parts and sometimes things change.
I myself never go back in with push-pins of any sort, they simply get too loose with a second use; I tend to replace all parts there with positive bolts or screws. I haven't used a plastic pin in years, they get tossed as I yank them. It stops rattles of all sorts too.
