bill65 »
https://forums.nicoclub.com/bill65-u178359.html
Thu Feb 03, 2011 5:28 pm
I own a 2007 Versa with CVT; at 64000 miles I took it to a franchise to have the 60K checkup & transmission flush service. At 76000 miles I began having a problem; at interstate speeds the engine will suddenly rev by 4-800 rpm, then drop back and do it again in a couple of minutes. I took it to the Nissan Dealer, they say the wrong transmission fluid was used by the franchise. According to the franchise invoice they used DEX VI instead of CVT NS-2 which is specified. The dealer says the warrany is void; the franchise says they ordered the fluid from the dealer via VIN #, so neither wants to be responsible. I expect the franchise will loose since they did the work. Here is my technical problem. The dealer says that if they just replace the fluid with the right one, it MIGHT be ok. The transmission is slipping pretty bad, I think I need a new one, what are the chances that after 12000 miles with the wrong fluid there is no damage to the transmission? My concern is- if the dealer changes the fluid and it is ok for a few thousand miles then starts acting up again is it the dealer or the franchise that is responsible to fix it?
Opinions & Advice please.
