BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sat Apr 07, 2007 11:02 am
The Versa's MR18DE engine is quite advanced. All aluminum construction, molybdenum coated pistons, form-in-place gaskets (should help prevent leaks in the future), improved coolant passages, micropolished bearing journals, variable valve timing, breakerless ignition...
