I also have the 4-spd and mine has a little vibration, but I am used to it after 30,000 miles. Is yours enough to numb your fott or you just feel it enough to ask? I think others have mentioned it in varying degrees.giggleface wrote:Hi there. I just got a brand new Nissan Versa 2010, 4 speed auto (not CVT). Only 100 kms on it so far. Wondering if it is normal for the Brake Pedal to vibrate when the car is stopped in when the shifter is in "Drive" (example, red light)? If I switch the car to "Neutral" or "Park", the vibration in the brake pedal goes away. Thanks.
giggleface wrote:Thanks for your responses. What is upgrading the ground wires and how can that reduce the brake pedal vibration when the shifter is in "Drive" and the car is idling (red light)? Thanks.
williamk10 wrote:i've tried bigger and more grounding wires..didn't help with the vibration.
I used to have it in my old car too, until I upgraded to a quality battery. I will be upgrading to an Optima Red Top soon
