Jemdawg »
https://forums.nicoclub.com/jemdawg-u48609.html
Mon Jan 01, 2007 8:22 am
Although a better battery may be helpful, you probably would want to invest in a capacitor as well, depending on how much power you want to run in your car. The battery will only run very efficiently when your car's engine is off, otherwise you will be straining your alternator. This is, of course, only if your system will be high powered; for example, I have about 2000W going throughout my car right now, and whenever the sub hits, which is at about 1000W a hit, my lights dim and my idle drops a little bit. A capacitor would help in this situation because it would hold enough power for every 1000W hit from the sub, while going easy on the battery, thus going easy on the alternator.
