Versa 1.6 upgrade wheels and tires from 14 inch to 15 inch
blockmap
Car: 2009 nissan versa 1.6
Hello, I have a 2009 Nissan Versa 1.6 with 14 inch wheels and tires and would like to upgrade to 15 inch. Will 15 inch wheels fit and will they change the speed and/or mileage? Thanks, John
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Theoretically, as long as you maintain the same outside ("rolling") diameter, your speed and odometer readings will not be affected.
But since the 1.6's 14s are so tiny and narrow, it might be hard to find a tire with the same rolling diameter in a 15'' tire. Fortunately, a lot of Miata tires are in the 205-50-15 range, which is about where you want to be to keep your speedo accurate. You'll probably end up being off by 1 or 2 mph at 65, but no more than that if you stick in that size range.
http://www.miata.net/garage/tirecalc.htmlThis tool is indespensible in comparing tire sizes.
blockmap
Thank you for your knowledge
