iliketocrash wrote:well when it said motor "set" i assumed it might come w/ the harness ecu and such. so then my only question was that if one thing included something important over the other? or whatever... i was way off i guess.
Depends. In the case of the RB series, you would want the clip for the crossmember and mounts. I dont think that is so much an issue with the CA,SR series because they were in these chasis and the stock mounts work (I think?? Not a 100%sure, I am a RB guy) Most time a motor set is eveything needed to run the engine. Engine, trtanny, ECU, harness, SMIC, etc. Shipping i smore on a clip, but you also have sometign to work off off. Misc bolts and **** if they work. You may also get aftermarket goodies with a clip. Plus with a clip, you can alsways hear it run if you really wanted to do the extra stuff involved to start it up
