Vents off, stil airflow coming through?
Juelze
Car: 2010 Nissan Rogue 360 AWD
Just want to see if this is normal or not. On my '10 Rogue (360 package) if I have the vents turned to "floor vents only" I still get airflow from the top vents. Also, if I have the fan completely off, I still get airflow through the upper vents while in motion. Is this normal?
Nick 568
Car: 2008 Nissan Rogue
Yes, this is normal. I found it strange at first too when I got my Rogue. If you want to turn the vents completely off, you need to have the fan in the off position, with the recirculate button pressed. (the orange light will come on) Note: this does not apply to defrost modes.
Juelze
Nick 568 wrote:Yes, this is normal. I found it strange at first too when I got my Rogue. If you want to turn the vents completely off, you need to have the fan in the off position, with the recirculate button pressed. (the orange light will come on) Note: this does not apply to defrost modes.
Thanks sir, that did it!
DaveNAna
Car: 2011 Rogue SL AWD Super Black
I could have sworn I tried that this morning and still got air flow from the top vents. I'll check again after work.
Return to “Rogue Forum”
