M374llic4 »
https://forums.nicoclub.com/m374llic4-u35918.html
Tue May 30, 2006 4:14 pm
No sir, the MAF is before the turbo even. The only thing before it is a filter, its the first thing so that it can measure all the air that comes in, then the turbo compresses it, then in to the intercooler to condense and cool the air then in to the manifold to await its turn to enter through the valves.
what happens is when you floor it, and build up boost then let off the throttle, just because you stopped giving it gas, the turbo doesnt magicly just stop, it keeps spinning pushing air into the intake, since it has no where to go since you closed the throttle it builds up alot of pressure and pushes against the turbo, which is quite bad indeed for it. So the Blow off Valve (B.O.V.) vents that excess pressure in to the atmosphere (atmosphereical blow off valve. sp?)
So now that the MAF told the ecu that, that air was in the intake, it then like datsunboy said, puts the amount of gas it thinks should be there in to the engine and then runs rich and bogs down a tad, just for a second though, till the ecu matches the MAF and injectors back up. Most would not even notice durring normal driving.
As for solution, yes, like datsunboy again said, a MAP (Manifold Absolute Pressure) sensor meteres the air that is Actually in the manifold based on the pressure in the manifold, so if your BOV vents, the sensor tells the ecu instantly, hey, there is less air, so put in less gas!
Then tada! no more bog!
