kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Tue Jul 07, 2009 7:31 am
I think all vehicles are like that to some degree, it's because the ventilation conduits run inside the vehicle and come into proximity with heat from the engine etc.., so it is impossible for the air in the conduits to maintain the same temp as outside. This would vary depending on the design for the conduits (i.e. their pathway and how close they run to heat sources), and insulation between the conduit and heat sources.
My Rogue is the same way, I agree it is annoying because on a cool day you don't want to feel warm air coming in from the vents, the only option to reducet his effect is to increase the fan speed which increases the flow rate of the air through the conduit and minimizes heat transfer, so the faster it flows the cooler it should be because it spends less time in the conduit which is when it gets heated up.
