BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Sat Aug 30, 2003 11:50 am
Those Signal Auto cooling system setups are SWEEEET.
They have a huge scoop, with ducting that goes from the front bumper, up to the front of the motor, where the intercooler is, then the hot air leaves though the vent in the hood, but then, also, on the bottom of the duct, the radiator is mounted at an extreme angle with puller fans, which pull the air out of the duct down and under the car. Gotta be the most efficient setup I've ever seen.
