p00t »
https://forums.nicoclub.com/p00t-u5026.html
Fri Oct 17, 2003 9:55 pm
Ever since I bought my 93 240sx the vent control (upper vents, lower vents, defrost vents) occasionally would not work, in otherwords it would be stuck on the position it was last set to before it decided to be a homosexual. It is very intermittent and random, but seems to happen more often in cold weather. This problem has previously been ignored because (A) When the windsheild started to fog up the vent door just so happen to be stuck on windsheild defrost. (B) When it was becoming more frequent it has been warm and no need for defrost. Unfortunately tonight it wasnt working and it was stuck on the upper vent mode, it was raining, windsheild fogged up 1/2way through the trip. It was not safe at all, and I dont want it to happen again.
Symptoms when this occurs are as follows:* Normal illumination of the unit is present with headlights on, but the LEDs on the buttons are not lit up (which show which vent mode is selected).* No matter what button I press the vents the air comes out of does not change.* Temperature control lever works perfectly.* Fan speed control lever works perfectly.
Any comments are appreciated. I will be pulling the control unit and checking the fuses tomorrow. If the vent door motor dies, does the whole circuit get cut or will the buttons still light like normal but doors just wont actuate properly? Any amplifiers or resisters that could go bad?
Thanks in advance!!!!!!!!!
