Shift_Kouki »
https://forums.nicoclub.com/shift-kouki-u46902.html
Wed Oct 25, 2006 10:13 am
I searched for a while, and did not find anything teribly usefull about where to get pistons for the KA.
I am trying for a daily driver here, so i plan to be NA. That being said, my rings are starting to go, and i was thinking some slightly higher compression pistons are in order.
However, i dont know where i would find pistons for a KA24DE that yeild a compression of 10.5-11 : 1 ??Please help me find a piston vendor!
The only other thing being done to the engine is a 240 degree intake cam from a 96 altima. To be used as an intake cam giving my '97 a set of cams with 240/232 durations.
As well as an extra 5 degrees of ignition timing, but i cant see how that would affect clearances within the cylinder.
But if either the cam or the ignition timing will cause any issues, please alert me to them now before i break sometihng.
