My chassis number is: apwe50-003727
https://nissan.epc-data.com/elgrand/apw ... 03727&ref=
The speed sensor listed as being fitted to my Vehicle is part number: 32702-vg219
https://www.amayama.com/en/part/nissan/32702vg219
I can' find any pics of VG219, only sales listings in Japan.
The parts diagram for the APWE50 is at the bottom of this page:
https://www.amayama.com/en/catalogs/nis ... n-unit-514
You can see that under the individual parts it lists 2 under "pinion assembly speedometer", these are 32702-33G19 and 32702-VG219. There is a picture attached to 33G19:
https://static.amayama.com/part/nissan- ... 60-big.jpg
This however doesn't loo like the the pinion assembly from my Elgrand which I have removed to check:
Whilst searching for 32702-VG219 I found this page which lists VG219 and being the same as 32743-74P19.
However google images suggests that 74p19 refers to the pinion itself.
There seems to be lots of aftermarket 25010-74P00 for sale which look exactly like my complete assembly:
I'm wondering whether to take a chance on 25010-74P00?
I've also noticed that Nissan list separate part numbers for the actual components that make up the whole speed sensor assembly. The pinion gear and shaft on mine seem to be fine. I'm guessing that its the part at the other end which contains the actual sensor and magnets/coils or whatever. Maybe I could just swap that bit out for a new one?
Would really appreciate any help with this one.
