Vehicle Speed Sensor - Is it my problem?
Choppa
Car: '66 Fairlane '92 240sx
My '92 240SX has been intermittently stalling on deceleration and the AT has been shifting way too high (3500-4000) into all gears . Well, using a ton of info from NICO club + 240sx.org I ran the AT self-diagnostics and came up with a code 1 and ran the engine malfunction diagnostics and came away with a 14 (Vehicle Speed Sensor.) As is common to many 240's, my speedo intermittently craps out - is that what's giving me the VSS error AND could it also be the cause of my other issues? Also, could anyone tell me what the code 1 for the AT means?
BTW - Trolling eBay I can find the FSM for $60-70 and a lot of CD's for $5-10...Does anyone have any experience with the CD's? I can tell you that I have the Chiltons and it sucks ***!!!
Thanks Alot,Choppa
ricebike
2002 Quest
2005 Altima
is the free online FSM link in my sig still down???
you've gotta check continuity on the wires to the sensor/ test the sensor itself/ then finally attack the cluster gauge...
code 1 and ECU trouble codes are similar to your problems: u gotta check the connection to the VSS... it's either shorted (most likely, since you say it works intermittently) or disconnected.
Modified by ricebike at 12:00 AM 9/11/2006 code 1 is the revolution sensor so check connections to it to see if it's disconnected or shorted to another wire... separate circuit from the VSS
rev sensor: black white wiresVSS: yellow/black stripe & yellow/blue stripe wires
Modified by ricebike at 12:09 AM 9/11/2006
Choppa
Yeah...The link to the FSM still seems to be down (looks like the billing Dept is lookin' for you)
Anyways - Thanks for the info!!! This weekend I'll trace the wires and check out the revolution sensor and the VSS. Wish me luck...
Peace,Choppa
ricebike
2002 Quest
2005 Altima
the info i gave is for the sohc engines from my 89 FSM... hopefully someone w/ the DOHC FSM can verify if they were the same colors...
Choppa
...Just a quick reply to thank everyone that contributes to the board...After searching the 240SX technical forum I solved the problem.
While backpinning the AT computer it became apparent that the Throttle Position Sensor (TPS) was the problem. It's supposed to spec out @ 1-10Kohms (closed - WOT). Well, the sensor was registering 9Kohms closed! I guess the computer thought the engine was at WOT all the time and that is why the transmission refused to shift until 5K RPM. $30 for a new TPS and the car is back in business. I just wish I had popped the hood and tested the TPS to begin with - my back is still killing me from removing the AT computer!!!
Again - Thanks everyone!
Choppa
