If you get a chance, post a link to the write up, because I can't recall ever seeing a 6-speed in a 3rd gen.
Unless you could do this swap easily, the VE transmission has a factory VLSD and seems to have pretty decent ratios. It would probably be cheaper and more efficient to have the stock transmission rebuilt to withstand more hp. I think internal parts can be upgraded.
If you go the turbo route, you are kind of on your own. Everything has to be fabbed up and I can't help you with that.
If you want to go all motor, here are some of the most common performance upgrades. The Y-pipe should be your first mod, btw.
CAI can be made (mine was custom made) or buy the one off of ebay and put on a real K&N filter
Y-pipe can be purchased from
http://www.warpspeedperformance.com ($200)
UDP at
http://www.aspracing.com ($110?)
cat back = any muffler shop or buy from Warpspeed, GReddy ($200-$600)
http://www.blehmco.com for ground wire kit or big brakes/suspension stuff. I think he is selling TB spacers, too. ($45 TB spacer, $60 wire kit)
http://www.jimwolftechnology.com for ECU upgrade ($600)
Maxima clutches are the same from 89-2001 I believe ACT and Exedy Stage 1 are preferred ($300-$400)
Fidanza Aluminum flywheel = search ($375-$400)
Putting on all of these items should put you into the mid/upper 14s in the quarter mile with street tires and maybe low 14s on slicks or drag radials. Mid 14s on street tires is about as fast as an Integra GS-R with I/H/E.
I ran a 14.8 and don't have an ECU and ran on street tires.
