redbaronk wrote:I had the same issue last month and with the help of the forums here came to the conclusion it was the brake pads being worn. The dealer confirmed it, and since the replacement all was well. I would caution you from just adding brake fluid to make the light go away.... I know many people do this, but what you have to keep in mind is that the system was designed on purpose to light up and notify us of a worn pad. If u keep driving on it u will screw up the rotor. A good dealer will charge u around 299 per axle (two pads)
Dealer did mine, 4 wheel pads and cut all four rotors at 85k miles and charged $530.00
I do not let anyone but the dealer touch my vehicle. Yes they may charge a little more but I get to drive a brand new loaner, enjoy some eats and the job is done right.
Telcoman
