vdc< slip, check engine
j2nd2none82
Car: 2005 infinity G35 coupe
I have a 2005 G35 automatic. i replaced my air filter yesterday and within 5 mins of driving away my VDC, check engine and slip sensers came on. they wont go off and now the car wont go over 25 and it idles really high like 1.5 almost 2 1000 rpm. anyone know what this could be?
marlin29311
Car: 2008 Infiniti G35x
Did you place the air filter on correctly? I don't believe this is related, but just a question...
When those lights all come on at the same time, it generally means that there is a problem with the VDC system in the car is malfunctioning - sometimes it needs brake fluid, but in this instance, it would appear something more is happening. Do you know how to pull the OBDII code for the check engine light?
suby01
Car: 2007 Infiniti G35x
hi.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
If it's related to the air filter, then the search function wouldn't have helped him.
marlin29311
suby01 wrote:hi.
In the time it took you to do this, you could have provided a useful answer.
suby01
i know.
toddnos
Car: 2003 infiniti g35 sedan
dirty MAF sensor????
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
pull the code... go to checker, autozone or an equivalent auto parts store. They have a OBDII reader you can use if you don't have one.
telcoman
j2nd2none82 wrote:I have a 2005 G35 automatic. i replaced my air filter yesterday and within 5 mins of driving away my VDC, check engine and slip sensers came on. they wont go off and now the car wont go over 25 and it idles really high like 1.5 almost 2 1000 rpm. anyone know what this could be?
j2nd2none82
Welcome to NICO
Check the electrical connector on the MAF. If it looks like it is connected, remove it and reinsert it securely.
I forgot to reconnect it after changing my air filter and the light came on.It will eventually go out by itself within 200 miles.The last time my light came on my gas cap was not on tight. After tightening it I started & restarted my G 5 times within a short time and the light went out.
If everything checkes out the ECU will in many cases eventually turn off a warning light.
Telcoman
Sentientbydesign
96 I30 - Sold
telcoman wrote:
j2nd2none82
Welcome to NICO
Telcoman
You may be on to something, but I think there's more to it. MAF fail safe usually includes max rpm limitation, retarded timing and rich AFR. The VDC, ABS, and SLIP lights indicate an ABS/VDC failure.
Kind of odd that both would come on at the same time.
uncbeers
And make those arrows straighter next time Suby! Sheesh...
As far as the OP, I had similar symptoms after an oil change once. Did the same stuff as I drove away. Once I took it back we saw it was just something they hadn't re-connected completely. Double-check and make sure everything looks like it has a 'home' and nothing is laying around unconnected. Sorry I can't be more specific.
infinitgkid
Car: '06 Infiniti G35 Coupe
+1
I skimmed over the OP's post and the MAF was the first thing that came to mind. It should be a simple fix
zozoka1212
Car: 08 Infiniti G35x
+2 on themaf sensor.
Op do you have the oem filter or aftermarket. Did you touch the maf sensor? Did you have to oil it?
Most likely dirty maf or not correctly placed maf.
zozo
Jacko3
Jacko3
I beleive a loose connector is the problem here. Find the connector and your problem is over. Next time avoid doing too many things on this car yourself---it is a temperamental car that requires a certain type of temparament to work on. Honestly, I don't have that temperament, and so I let my Tech do all the work. He has never done work twice on my car--always done right the first time. All i do is check for oil level---thats it! I cannot bear to know that I am the cause of an array of electronic madness on the car. There are to many sensors on the car. The car can even detect a person's breath with all those sensors (just kidding).
toddnos
Jacko3 wrote:. Next time avoid doing too many things on this car yourself---it is a temperamental car that requires a certain type of temparament to work on.
I disagree. I work on this car myself.
Jacko3
I guess you have the right temperament. I am still searching for the ight attitude to work on cars---I haven't found it and i don't wanna screw up anything on my cars.
toddnos
Jacko3 wrote:I guess you have the right temperament. I am still searching for the ight attitude to work on cars---I haven't found it and i don't wanna screw up anything on my cars.
oh, i make plenty of mistakes along the way, but i prefer to take some risks to gain reward.Paying to have bolts turned by someone else is a foreign idea to me.
Jacko3
I would generally agree based on that philosophy. Er......I think I still want my Tech turn those bolts.
tollboothwilley
Jacko3 wrote:I beleive a loose connector is the problem here. Find the connector and your problem is over. Next time avoid doing too many things on this car yourself---it is a temperamental car that requires a certain type of temparament to work on. Honestly, I don't have that temperament, and so I let my Tech do all the work. He has never done work twice on my car--always done right the first time. All i do is check for oil level---thats it! I cannot bear to know that I am the cause of an array of electronic madness on the car. There are to many sensors on the car. The car can even detect a person's breath with all those sensors (just kidding).
I love working on my car. I hate letting others touch it now.
Thats what I used to think...til I got my hands dirty. Then its all you.
toddnos wrote:oh, i make plenty of mistakes along the way, but i prefer to take some risks to gain reward.Paying to have bolts turned by someone else is a foreign idea to me.
AMEN Brotha
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
I'm with you guys, I don't like anyone else touching my car, let alone turning my bolts...
