VDC Off, Slip and Brake light HELP?!
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
uncbeers
So this AM on the way to work, all seemed fine and then 5 mins before my parking lot the 'VDC Off' 'Slip' and 'Brake' light all came on. I know there is a section in the manual about this but haven't been able to check this yet as I am now at work.
The catch on this is I am wondering if it is related to the oil change I got this last weekend. I got the oil done and all seemed fine until I drove it and all the warning lights (including the Service Engine Light) were on and it was shimmying at speeds of 30mph+. I went back and saw they had left one sensor unhooked and they fixed it in no time and reset the car's PC to get the service light off. I have driven some since then and all was fine until now this AM and the 3 lights came on.
Any ideas on things to check? I am worried and hoping this isnt severe as I just bought it and don't want to have to put it in the shop-unless it needs to be done of course! It is a 2005 G35x.
THANKS to all!
joe603
Car: 2014 Durango R/T
I would try to reset the ECU first, then if it happens again, take it to a dealer.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
check your brake fluid level
WhiteG35Bullet
Car: 03 G35 CoUpE 6Mt
Same thang happen to me when I was street racing and was in 3rd gear and meant to shift into 4th and accidentally shift into 2nd and redlined the 2nd out. And all the lights came on. What I did was take it to a friend shop and he check whats was wrong and just reset the ecu and he told me if the check engine light comes back on within 1-2 wks then it means it need to be diagose if not then your OK! N the slip and vcd can be reset if you diconnect the battery. Hope that helps
uncbeers
**EDIT-so on my drive home the 'brakes' light turned off and then once I got home and turned the engine off and on again the VDC and Slip light turned off. I know I've read some on this but any idea what this means for sure? Thanks!
Thanks for the help so far.
The Check Englie Light hasn't re-appeared so knock on wood that remains true. I will get it home here shortly and check the different things.
It is strange it happened right after the oil change and they did have the issue with not connecting the sensor so I hope it is something simple. But truth is, the breaks are louder than heck at near final stopping speeds so I am wondering if it is saying it is time to do them? Hoping it wasn't so soon but if it is time I guess it is time.
Thanks for the help and if anyone else has any comments/advice, send em on over!
Modified by uncbeers at 7:35 PM 1/8/2008
infinititech1
check brake fluid level....
johnlungchow
Car: g35
I had the exactly same problem that u have right now.actually, i just fixed the problem today.the reason why all the lights went on is because u have the wrong sizing for the tires.do u have stock rims and setup?i have the 19inch225/40/19245/40/19 when i used these for the rear(255/45/19), my thing turned on right after i put the wrong sizing tire.Since the VDC control thinks i am slipping so the stupid computer decided to stop working and let me deal with it by dis function the VDC, so the lights turn on. Yes, all of them, slip, brake, and the VDC offbut i finally finished running the tires until one of them poped two days ago.and now, this problem is gone after i put on the stock size.so go change the tires if this bothers u.hope this helps, let me know if i am right^^
uncbeers
Thanks for this but it is the stock stuff still. I topped off the brake fluid and the lights haven't been back on (knock on wood...).
I do think it is time to do the brakes though really and this may be the cause if it happens anymore.
Thanks for the suggestion however!
johnlungchow wrote:I had the exactly same problem that u have right now.actually, i just fixed the problem today.the reason why all the lights went on is because u have the wrong sizing for the tires.do u have stock rims and setup?i have the 19inch225/40/19245/40/19 when i used these for the rear(255/45/19), my thing turned on right after i put the wrong sizing tire.Since the VDC control thinks i am slipping so the stupid computer decided to stop working and let me deal with it by dis function the VDC, so the lights turn on. Yes, all of them, slip, brake, and the VDC offbut i finally finished running the tires until one of them poped two days ago.and now, this problem is gone after i put on the stock size.so go change the tires if this bothers u.hope this helps, let me know if i am right^^
bublightyear
Car: 05 g coupe
Same problem, different answer....one day the lights just popped on. Clearing the ECU didn't work, checked all the fluid levels & nothing worked. Took it to the dealer & they said I must have hit a pot hole or really rough road or something cause the the plug wasn't making good contact anymore. $200 for them to plug wires in completely.
uncbeers
OMG-friggin dealers. That definitely sucks man-least you know where to come next time before going to them!
bublightyear wrote:Same problem, different answer....one day the lights just popped on. Clearing the ECU didn't work, checked all the fluid levels & nothing worked. Took it to the dealer & they said I must have hit a pot hole or really rough road or something cause the the plug wasn't making good contact anymore. $200 for them to plug wires in completely.
toddnos
Car: 2003 infiniti g35 sedan
uncbeers wrote:So this AM on the way to work, all seemed fine and then 5 mins before my parking lot the 'VDC Off' 'Slip' and 'Brake' light all came on. I know there is a section in the manual about this but haven't been able to check this yet as I am now at work.
THANKS to all!
what sensor was left unhooked? and how does that relate to an oil change? This whole thread seams strange...a bunch of nameless sensors unhooked, or not making contact?Thanks god i can work on my own car, and dont rely on shady dealership/oil change shop mechanics...lol
zozoka1212
Car: 08 Infiniti G35x
It is most likely your brake. You'll need more fluid because the pads are worn. Time for the brake upgrade.
Anything in mind?
Brembo?
zozo
Otis35
Car: g35 coupe
this just happened to me over the weekend, pair of new rear tires installed@the dealer. My G went into limp mode.
G35Love
Car: G35 Daily Driver 240sx takes care of business
I have a similar issue but I cant get the car in drive to take it to the dealer. Middle lamp was out so i tried to test the connections and now non of them work. Usually you can hear the click in the center console but now I hear nothing.
uncbeers
Sorry guys...all I can offer is mine was brakes. It was definitely time for them after I got in there and saw them. Did front and back and had no problems since...(fingers, crosed, knocking on wood, all that jazz).
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
#1) check all fuses#2) check all fluids#3) check battery
if brakes are dead then it will need more fluid and will turn brake light based on more fluid out of the master cylinder.
I've had battery issues turn lights on before, and fuses.
Times like these are a good chance to make sure you are following up with the maintenance of your vehicle.
suby01
Car: 2007 Infiniti G35x
zerothread?id=316679here ya go.
and p.s. it happend to me again and took it to the dealer and they said it was a camshaft position sensor that went wrong. so they replaced it for me.
G35Love
Mine was a blown fuse, and a blown backup fuse. Couldnt even drive to the store to buy a fuse since the brake lights wouldnt go on, it wouldnt let me drive.
topnotchg
Car: 2005 G35 coupe
hope u found the solution
suby01
dropped it off at the dealer today for the same thing see what they have to say.
and yupp once again its the camshaft position sensor.
Modified by suby01 at 10:17 AM 4/30/2008
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
