VDC off light and slip light
Nissan 350z / Nissan 370z general community discussion forum
silverlion87
Car: 350Z
I've got a 03 manual 350z and my VDC off light and slip light keep coming on I've cleared the ecu all my fluids are at the proper levels and my front breaks are good but i did change from the 18 inch rims with the whole pressure monitoring sys to a newer set of 17 inch rims without the tire sensors
So I was wondering if anyone knew of anything else I should try to do before taking it to the dealership because they said it would be $100 just to run a diagnostic
andreyd21
Car: g35
yeah i have the same thing on my 04 manual g35 every time i start driving vdc off and slip turns on. was your car wrecked or any damage to the back wheels
Modified by andreyd21 at 12:42 PM 6/6/2008
BlackSmoke
Car: 2007 350z Grand Touring
What tires do you have. The reason is sometimes if you dont have the "standard" diameter for the car then the slip and VDC thinks your tires are going faster than they are calculating thus putting the lights on and off.
CABhc4life
Car: 2006 350Z
speaking of lights...
and this is completely off topic...
but is there a way to get your overhead lights on the interior to come on when you open the door?
Mine don't come on, and it can be a pain sometimes.
Watermelonwarrior
Car: 2006 Cayman S 6SPD
there is a button you slide over on the top of the lights by that little compartment for your sunglasses.
dasoupdude
Car: 2005 Nissan 350Z
CABhc4life wrote:speaking of lights...
wow lmfao..look for the lil switch near the map lights,
audtatious
I thought when VDC and slip lights come on it is an indicator that you need new brake pads?
Thought I saw that here somewhere. Anyone confirm?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
That is an indication. But there was also issues with brake switches causing this problem. How are the rear pads? Are you getting a brake light with the vdc/slip light?
adren77
Car: 2004 G35 Laser Red Coupe 6MT
Did you ever resolve this issue? I am having a similar problem with my G35. The VDC and Slip light come on. My tachometer also doesn't work when this happens, but the car rides just fine.
beloman
Car: 2008 Nissan Rogue SL
Mine turned out to be the brake (stop) light switch was becoming intermittent....dunno why I didn't deduce the connection to the VDC/SLIP light but fortunately I got to the dealership with the bugger acting up and as the code was apparently still in there and the VDC/SLIP light illuminated so I could show them the issue. :crazy:
Return to “350z / 370z Discussion”
