VDC off Lamp illuminated
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
fxgrub66
Just had my tires rotated last week, and now the VDC lamp is coming on for no reason. Has anyone had a simular experience? If so, what did it take to correct the problem.
AWGD8
Car: 2008 EX35 AWD JOURNEY
Is the VDC light intermittently on and off or steady? There is a VDC switch located lower left of the steering under the dash , typically above your left knee when you sit on the driver side.
The only thing I could think of is low brake fluid due to break pads getting thinner and needs replacement.
fxgrub66
The light is on all the time. I have tried turning the VDC switch on and off, but that did not make any difference. I am going to check my brakes as per your suggestion though. The vehicle has only 38000 kms, but all of it has been city driving. I will be replacing my tires as well as the Dunlop SP7000 tires have gotten so noisey, it sounds like a off road truck on the road.
fxgrub66
I should have my a** kicked...added two tablespoons of brake fluid and voula...VDC lamp is off. Thanks for you help though.
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
:picard:
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
