Vdc off and traction control lights
Hill88
Car: 2008 Nissan Rogue
both VDC off and traction control lights come on after I drive and hit brakes they stay on till I restart my Rogue I read to replace the brake light switch I did it didn't fix issue I have used my scanner to pull codes when lights r on there is never any codes. Havnt had any issues with throttle. The problem accrued after I had removed peddle assembly when I replaced blower motor and resistor after I reassembled this problem occurred. Also the cruise control doesn't work either turns on but won't set anyone know anything that will cause this.
RicerX
Car: '20 Titan Pro4X
Welcome to NICO!
Typically, if the VDC off and TCS lights come on simultaneously, it's due to low brake fluid. Have you checked that? This particular problem also will not throw a code into the system IIRC (this same thing happened on my 2008 Altima 3.5, which was a result of not being topped off correctly from the factory).
Give that a shot before we get too much further into troubleshooting - it's the most common cause. If not, we'll look further into it.
Hill88
I topped off brake fluid and still no change I adjusted the brake switch and cruise control switches. The front brake pads r like new the rear are low so I'm going to change them to see. All the wheel speed sensors are responding great and don't seem to have any issues there.
Return to “Rogue Forum”
