RED_DET wrote:It is located on or near the throttle body. I doubt that is your issue, if it won't even turn over. You sure you have a good connection on the battery terminals?
+1
I have an 06 but when checking my battery cells with a hydrometer a couple of weeks ago I noticed that the positive battery terminal has two connections off the positive terminal.
I believe that if the 05 is similar than one of them is making good contact accounting for the dash lights but the other one may go to the starter selenoid. If that is not making a good connection that would account for a jump start not working either.
Check all battery connections
Telcoman
