The sensors need to be reprogrammed if they're put in a different location, otherwise you'll get asterisks instead of a PSI reading. Your other issue can be any number of things.Hartley33 wrote:These lights come on when I drive and sometimes they do NOT come on when I'm in drive.
I had all 4 tires changed to new tires but now the PSI for the tires doesn't work either. I don't know if the dealer subbed out the tire job--- I have asked this.-The car is an 06 M35 base I purchased used after a full check.-- I can't afford this!
I am planning to get a second opinion. Does anyone know if Auto Zone or is there another non-dealer Infiniti repair group that can read the codes? I have heard on the board this can be a) low brake fluid b0 a camshaft sensor c) a wheel sensor-- any number of things. I have asked if the car is SAFE mechanically to drive due to an over-ride system? Any comment?
I live in the SF Bay area of Calif.
