I have just recently purchased a 2004 Maxima with some issues. First I replaced the timing chain and guides it sounded like a meat grinder. Then about 2 months later the oil pump failed and I had to put an engine in. The car has right at 110,000 miles on it and it is a beautiful car. Now I have a "VDC off" light is on and the car is in limp mode. The 3 codes were for MAF, O2 sensor & IAT.I have cleared the codes and the only one that stays is the MAF. I have check the resistance on the wires from the ECM to the MAF pins, check the battery voltage at the sensor and checked the ground wire to the MAF. Everything is in spec. should I replace the MAF again (only 6 months old) or should there be something else I should do. Will this cause the VDC light to come on or is there still another issue. I have checked the brake fluid, replaced 1 abs sensor and cleaned the others. I see that there is a ecm programming for this vehicle for the VDC light, should I take it to the dealer or is there another test that I can do before that!
