ell »
https://forums.nicoclub.com/ell-u299740.html
Fri Jan 08, 2021 9:43 am
Hi! I have a question. I own a 2017 Altima SR and yesterday I took it to get a speed check (required for work). After the speed check was done, I got back in my car and noticed the VDC light is on (is that the car with 2 squiggly lines). Not sure why, maybe during the speed check (since I think they run the car on rollers) caused the light to come on?? I checked the brake fluid, seems good. Car runs well, brakes are normal. Is there a way to turn this off? I pressed the VDC off button- now both lights at on, pressed it again to turn it off but the other light is still on. Help? Thank you!!!
