vavle seals
GkidDrift
okay so i posted a while ago saying i had low compression in all my cyliders.and was told i needed a new engine.but my brother in law was thinking maybe it was the valve seals. so we took off the head flipped it over and it looks like there arnt even any seals there.im jus seeing if ya'll think this could cause low compression and a puff of smoke out my tailpipe everytime i press on the gas.
thnks guys(ladies?)
BadMojo
Car: 2007 Mazdaspeed 3
Low compression, yes. What color is your smoke?
Anyway, I'd get a leakdown test done (shouldn't cost much) and pinpoint *exactly* what is causing your low compression instead of just guessing.
Nismochick240
Car: 95 240sx- BONE STOCK.. for now
hey if your in the south carolina area i can do a compression test for you-- valve stem seals could be makin ur car smoke-- thats why mine does haha-- does it skip or not run @ all??
180fan
Car: 89 fastback
valve stem seals, if they're bad or in your case not there, will make you burn oil (your exhaust smoke should be tinted blue-ish as a result).
How many miles are on the motor and are you positive there aren't any valve stem seals on it? I find it highly unlikely that you're missing valve stem seals unless the previous owner tried messing with it. In which case, you might also want to try doing a leakdown test as well.
GkidDrift
its got 100k+ on it.well the perv owner took shortcuts everywhere to make it look ricey. so i wouldnt doubt he did somthing.but im having the head rebuilt 2mrw.and yes the smoke is bluish greyish
