SRBURG13 »
https://forums.nicoclub.com/srburg13-u1642.html
Mon May 12, 2003 3:01 pm
There is a white screw between cylinders 2 and 3 on the intake manifold. Just look straight down between the "rounded pipe thingies" (to be technical), and turn to the left slightly. You can mess around with that a touch and it should bring up the idles for you. This screw controls some kind of engine air/fuel/idle stuff. I don't know exactly. I may be wrong on what it controls, but it should help you out a little bit.
