s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Mon Mar 14, 2005 8:25 am
vvt should really help out your midrange punch(nissans trademark powerband). what rpms do you see on a regular basis. all nissan vvt systems that i have had to mess with advance the intake cams around the midrange and then retard them again at the high end. the reason for the advance is that it gets the valves open earlier for valve overlap and the scavenging effect. as the rpms go up that weakens and more power is found by holding the valves open a little longer and letting the "air column" just ram its way on in. if you are only going for top end hp then a simple adjustable sprocket will prob net you more total hp.
