Vanity mirror bulb replacement.
grissoly
Car: 2004 Nissan Pathfinder Armada
The right vanity mirror light bulb is out on my 2006 M35X. My owner's manual doesn't show how to replace it. Is there a diagram that tells me how to remove the cover?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
grissoly
Appreciate it! This helps a lot!
VStar650CL
Technical Expert
You're most welcome. Happy motoring!
grissoly
Took the bulb out. Doesn’t look blown so I have another issue somewhere.
VStar650CL
Technical Expert
Swap with the other side if you want to make sure.
grissoly
Tried the other bulb. Doesn’t light up.
VStar650CL
Technical Expert
The next most likely culprit is a bad switch in the sunvisor. The connector for the visor pulls down out of the headliner when you detach the mounting, put a test lamp across it. If the test lamp lights then the problem is the contacts inside the visor.
