eduJ »
https://forums.nicoclub.com/eduj-u223833.html
Sun Mar 30, 2014 12:06 am
Can you describe to me some of the symptoms that you are experiencing? The pathfinder/qx4 is known have shift sluggishly from 2nd to 3rd as well as having a hard shift from 1-2. So if you are experiencing those symptoms, I wouldn't worry about it as it just seems like it's a characteristic of our transmission.
If you are experiencing delayed engagement (i.e. from P to D or P to R), it is usually due to worn seals. This is normal as the car ages, but there may be things that you can do to help. Transmission seals harden quicker as temperature rises, so the lower you can keep transmission temperatures low the better.
I would avoid the Lucas transmission additive as the reviews that I have read appear to be mixed. I would do a drain and fill rather than a flush at this point. I have heard mixed opinions about doing a flush on a high-mileage transmission that has been neglected. So go ahead and drop the pan, clean out the magnet and pan, and clean the strainer (aka filter). After you have done this, you can do a couple more drain and fills over the course of a couple weeks. After 3 drain and fills, you will have changed out the majority of the fluid. I would then add Lubegaard Red additive with your last drain and fill. Apparently, it helps keep temperatures low and free up sticky valves, etc. It seems to have helped with my engagement delay so maybe it has some seal conditioners in there as well.
Hope this helps
