180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Oct 26, 2004 7:26 am
Use the COMP springs. I got mine from Enjuku, paid about 150 for them. Very nice and from that same lineup of springs, they're nothing to scoff at either. The Ferrea's I think are over priced for the marginal preformance difference over the COMP. You can get the Crower titanium valve spring retainers (I did) with the Comp springs and still come out cheaper than the Ferrea by about 200 bucks.
Tomei always builds good stuff, but it depends on you if you're willing to pay the premium for them.
The cams from HKS are good. Even with the new grind they're using, they're still very streetable if you get the step 1's. That's what I got now and enjoyed before I had to pull my motor for a rebuild. I've heard reports of them gaining anywhere from 10-20hp so that should be pretty good gains just for cams.
The Tomei Procams you must get the new valve springs, while the Poncams you don't. But with the lift you get with the Poncams, get the springs anyway. I've tried out the Tomei's and they're very good, just pricey. Up to you if you want to spend that premium for Tomei.
I got my set of HKS cams for under $400. Tomei's are usually like what $500+? That extra hundred bucks is a pretty big margin and personally didn't think it was worth it. But it might be to you. Poke around some more and call around some shops like Phase2 or Enjuku as they've probably got more opinions on the matter.
