WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Apr 25, 2003 9:25 am
Get a good 3 way valve job done while your having the head ported. Make sure you get the intake and exhaust mani(turbo mani) gasket matched so the air flow will be smooth and unobstructed. Also, grab a set of S13 Exhaust cams, they have longer duration. I believe 248 was the number. You'll need a new cam pulley on the intake side, but you can buy one from JWT.
I recommend Extrude Hone for any port/polishing work.
WD
