lucky wrote:The question is....will your car still make power at 9k rpms? There is no point to spin your motor that high if you aren't making power. It won't happen on a stock turbo...that's for sure. Cam sizes really depend on what you want out of the car....if you are putting a smaller turbo on the car, use 264 cams at the most.
I'm doing the buildup in stages, and one of the main considerations I'm putting into it is how often am I going to have to open the motor? I want to get the motor internals fortified before it goes into the car. From what I've read, the stock bottom end should take ~400chp, and I'm only looking to make ~300-350whp.
I guess the question I should ask is, will doing the cams and springs significantly hamper stock turbo driveability, for the 6-12 months that I'll be running on the stock turbo?
Quote »... I would recommend getting some titanium retainers and rocker arm stoppers while you have the head off.[/quote]
Those help hold more boost, right? Do the stock retainers and rockers start to have problems around 1 bar or so? Or maybe up at high speeds, like 7k+?
Quote »edit: if you really want to go all out, get some over-sized valves and have the head ported and polished. [/quote]I'm only looking to make 300-350whp. At what sort of hp / tq numbers, does head flow start to become a problem?
