rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Fri May 16, 2008 11:37 am
So, I wanted to try this topic again.
About a month ago, I heard a slight tapping noise when the motor was at NOT. Not cold. Only when the coolant 180* or above. The noise sounds like it is coming from the intake cam around #4. I pulled the valve cover and rotated the engine to check clearance between the lifters and the cam, and there was no gap. The noise only happens when hot. It has gotten a little louder, but no worse. I have changed oil three times since (15W-50 Mobil1, 20W-50 GTX, and now to 10W-40 Syntec) with some Lucas stabilizer every time. I have also run a motor flush with one oil change. The other thing is that the noise only happens at medium load. Light load or idle, nothing. WOT, nothing. Only medium (crusing) load. It is driving me nuts!!
