Valve train noise
72 510
I have a newly installed red top in a 89 chassis. the motor has 27K and runs real strong.
My issue is the motor is smooth and quiet until 2600-3200rpm it starts making a tik-tik- sounds that is coming from the back 1/3 of the motor. if I slowly rev the motor it tiks from 26-31 and then quiets until 4k+. if I cruise at 2800 and have a nuetral throttle positon it tiks, if I decel or accel it goes away. if I hammer it then it comes back around 4+. it nevers tiks on decel.
any ideas? I removed the top timing chain guide but it sounds like valvetrain. I also changed the oil again.
It seems to be more throttle position dependant which leads me away from the HLA and more towards a EFI problem on one injector or ingintor?
SpeedRacer1
Car: 1990 240SX, G35
And its not an exhaust rattle?
72 510
Not that I can tell.
I stick a screwdriver up to my ear and place it against the valve cover and its definetly coming from inside.
I wish it was exhaust. it sounds like timing chain slapping against metal but its in the back?
Jesse SR20
Car: 1990 S13 fastback
You could always dig into the head and bleed the HLA's. They tick when they have air in them. And while you're in there you can look for abnormal wear or anything out of place.
72 510
I would rather not tear the cams out right now if its not the problem.
I can't see it being the HLA's unless it was a consistent tick from idle up. just a slight change in throttle position shouldn't make the sound go away if it was the HLA's.
The sound is like a grrrack
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
pull the valve cover off and just check that everything looks alright. Removing cams is easy as hell anyways.
Nismo_Freak
Car: 89 Nissan 240SX
You don't even have to remove the cams to remove the HLA's.
Just spin the motor over by hand until the cam lobe isn't contacting the rocker arm, pop off the rocker arm, and now you can remove the HLA.
72 510
Does it sound like a problem with the HLA's?
I'll pop the cover off tommorow. I just didn't want to spend time going down the wrong path.
Nismo_Freak
Honestly I have no idea, you can't really get a picture of what a sound is from it makes this "tik tik tik" noise haha.
I would say it's not a HLA problem, and that it would be more likely an injector since it doesn't do it on deaccel.
72 510
Turns out the bearing caps on the intake cam were all loose by alomost a full turn.
I cleaned and primed the HLA's, tightened everything down and the noise is better but still there.
The HLA's were in excellent shape.
I checked lash while cold and couldn't fit a 0.0015 feeler in any. all had a slight gap as I could move the rockers.
I'm now at a loss?
Nismo_Freak
72 510 wrote:Turns out the bearing caps on the intake cam were all loose by alomost a full turn.
I'm now at a loss?
I wouldn't assume that was your only problem. You still will want to investigate the fuel injectors, I had one on my SR20DE get loud on me.
spider_slayer
Car: S14 240SX
S13 240SX
i think all of the caps have a specific torque spec......when you tightened them did you use a torque wrench?
