I have posted many times before about my vibration problems. Anyway I got to thinking that I also have a valve train noise that I assumed was one of the lifters. However, could this type of noise also be caused by a faulty injector? I ask this because I was thinking that I may have a power balance problem that is causing the vibration and that this might be injector related.
I realize that this is a vague description but the vibration seems to be better and worse almost depending on the weather and whether the car is cold or heated up. Today I notice that it was still there all the way through the speed range even at a constant 70mph. Other times it seems really bad at lower speeds particularly on acceleration and then disappears at high speed
