valve/timing???
vmiramon69
Car: 1993 s13
i guys im victor i live in conroe tx, i have a 93 dohc i need some help guys i been a member for a lil bit and i know the SEARCH button pretty good lol.well i just rebuilt my motor i put everything together myself and machine shop did internals... new gasket new apr studs...well when i got the motor back it had crazy compression... when i put everything together idk why i took off cams and than i lost the compression...i did the oil in the cilinder trick and it help it a little bit... still no good comp.. and now i set the timing right TDC on #1, but valves on intake side won't come out and play
WHAT IM I DOIN WRONG GUYS
Modified by vmiramon69 at 12:33 PM 9/13/2009
Modified by vmiramon69 at 12:49 PM 9/13/2009
vmiramon69
Car: 1993 s13
someone please...i would really appreciate itim goin nuts
youngun21a
Car: 240sx 1993 Automatic
So when u say that the valves won't come out and play u mean they stay down..and when u put everything back together..did u do a free turn before u turn it on..if not u could have bent the valves...and by the looks on the 2nd pic with the pully it looks like it on the 3rd notch and it should be the 2... http://www.nicoclub.com/articles.php?id ... .g-offgood read..
vmiramon69
Car: 1993 s13
thanks bro but that angle on that pic is at the 2nd mark on TDC on crankshaftthe valves on the intake stay down yes....picture #4 .... could there be another reason why they wont come out besides being bent????im trying to find other solutions before i take the head off
thakns
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
once you rotate the motor the marks on the chains and the cams arnt going to line up anymore. thats just a refrence point to start from. it looks like everyting is lined up now if your at tdc on the #1 cylinder your cams should point out to the left and right. but none of this really matters because your valves arnt coming up so whatever damage that could have been done is obviously done now. remove the head. its the only way to find out if your valves are bent. dont rotate the motor. if your valves are bent thay have contacted the pistons and will either put a hole in the piston head or shove the bent valve into the valve guide and then you will really be in trouble. as far as other options for the valves not coming up. broken valve springs. valve buckets locked in head from either extreme warping or debris between bucket and head, valve locked in valve guide from debris. all of these are very bad and would require removing the head to have fixed. sorry.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
+1 if the valves aren't coming up they are bent, no question about it. At least they are relatively cheap for new ones.
vmiramon69
Car: 1993 s13
thanks for the help guys i will take that head off asap... and will update soonagain thanks!!!!
vmiramon69
Car: 1993 s13
so i have bent valves hehehe
youngun21a
That sux dude..well i least u know ur engine inside out..
