Valve ticking VG30E
Discuss topics related to the VG and VE series engines.
Dattebayo
I have a S12 VG model, so the motor is slightly different, but maybe you guys who have worked on the non-interference motor with W series heads may know what I'm on about here...
I started up my car after about 1 month of non-use. Battery was dead (of course) but the thing started right up after a jump. It was really bad ticking at start-up, but not as bad as a diesel or anything so I let it idle for about 1.5 hours to charge the battery.
I came back after the 1.5 hours to find the motor still idling loud. It sounded like the valves were tapping pretty loud to me. Is there a known issue with the VG W series heads like this? Is there anything I can put through the motor putting off the head change?
Perhaps I should check the pump or the channel to see if it is clogged a little? What do you think?
that_guy
Car: 1996 nissan 300zx 2+2
mines doing the same thing, but theres no oil pressure lol.
Dattebayo
O NO LOOK OUT! It's "that" guy!
Yeah, my oil pressure was kinda low too, but it was at idle...More info to follow tomorrow when I get back from work.
that_guy
Dattebayo wrote:O NO LOOK OUT! It's "that" guy!
ack! where is he?!? from what i understand, valve ticking is pretty common for our engines..i let mine stall one night after some galavanting in a mall parking lot.. when i started it back up, it did the same thing. id never heard it before so i left it. when i picked it up the next day the noise got louder, and there was no oil pressure.poking at the intake cam from the oil fill doesnt fix it.. i tried that already. :D
Dattebayo
that_guy wrote:from what i understand, valve ticking is pretty common for our engines..
LOL we don't have the same engine. I have the SOHC, chief.
that_guy
you should still have the same hydrolic lifters tho.. i know its a sohc, but its still a vg
Dattebayo
I thought DOHC had cam over bucket? You got rocker arms in there?
that_guy
oh damn, my bad. im just bored. sorry dude. im still browsing this huge forum... ive got a buddy with a couple of 30th's, i know most of my stuff about those motors from him. im still a newb when it comes to z's tho, ive only had mine for a year.
Dattebayo
Well, one more post and you can go buy yourself a VG30ET and pick it apart and get yer learnin' on. That's how I started, my absolute first motor to ever pull apart, too.
I still want my problem solved.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Its most likely one of the hydraulic lifters. The bleeding procedure is to run the engine at 1,000 RPM with no load for 10 minutes.
HomelessRonald
Car: '00 Frontier KA24DE
This stuff is really good. I used it on my VG aswell as others.http://www.z1motorsports.com/p...f63f8
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Adding half a quart or more of 20-50 weight synthetic blend oil might help, and then convert to full 20-50 weight synthetic blend next oil and filter change.
Dattebayo
Synthetic? Yuck. I don't have enough invested in this car to justify spending that much on oil. Will dino oil be just fine? Also 20 is a little high. Are you sure I should be using such a high number? The highest I used in my turbo Z31 was 15-50...
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Dattebayo wrote:Synthetic? Yuck. I don't have enough invested in this car to justify spending that much on oil. Will dino oil be just fine? Also 20 is a little high. Are you sure I should be using such a high number? The highest I used in my turbo Z31 was 15-50...
Don't know how similar your motor is to a VG30DE, but I onced parked my J30 due to leaky water pump and waited a couple of months to fix it. I had to move the car every couple of weeks and before long I was more concerned about a loud clicking sound every time I started the engine (with about 167K miles on it), than I was about the leaky water pump.
After I replaced the water pump, timing belt and all, adding half a quart of 20-50 synthetic blend quickly quieted what was apparently a sticky lifter. The best $5+ I ever spent and synthetic really is more slippery. Next oil/filter change I switched over completely.
Dattebayo
GerryO wrote:Don't know how similar your motor is to a VG30DE
Not similar at all in terms of valves. The only thing a DOHC has in common with the SOHC is the bore/stroke of the cylinders/pistons.
Sorry.
Return to “VG30 / VE30 Forum”
