Valve taps + engine oil relations?
bigpei
Car: 2006 g35 coupe AEM CAI, Skunk2 Plenum Spacer, Evo2 TT 3" TI Exhaust /w Test Pipes, Nismo Headers
Hey guys, i have a 06 mt coupe and it only has 10k miles on it. i do push it time to time. i can hear valve taps, and sometimes after a long drive it gets really loud. i do my oil changes every 2000 miles and i use mobile 1 synthetic 5w-30 oil. the dealer ship had already tested my car for consumption test and it was fine. anyone know if anything is wrong? or should i just add in 1 quart of oil every 1000 miles? any suggestions would be greatly appreciated. thank you
C-Kwik
Only add oil if the oil level drops. If you are sure its valve tapping, perhaps try a slightly heavier oil.
TJMaxx98
Car: 2004 G35 Coupe / 2008 FX 35
What type of gas are you using? 87, 89 or 93 That might cause a pinging noise??
I had an 86 300zx with 150K, it would make a tapping sound when the oil needed to be changed. Usually around 3000 miles on the oil....the shop said it was just weak lifters. But it was pretty annoying.
