jEzTeR wrote:What iol is best to use in between changes?
As long as you do the oil and filter changes regularly (3750 miles or less), any good Dino 10W-30 or 5W-30 oil will do just fine! Of course, changing to better/proper winter and summer weights is a good idea if you are in cold climates. Per Fred's posts, Chevron Supreme and Castrol GTX are among the best Dino oils you can find.
Personally, I like treating with the best I can do for oil. So, I use Mobil 1 Synthetic 0W-40 (all initial oil used through 7500 miles were Dino though!) as a good all-around excellent oil for all climates, short of being in Canadian winters!
The engine takes 5 7/8 quarts to fill (with an oil filter change) - I simply ask for the oil drain to be done a tiny bit more thoroughly and then add in all the 6 qt bottles I get. This just barely gets below the completely full mark when stone cold!
In between changes, I typically add about 1/8 to 1/4 quart at the 1750 mile mark (about halfway between oil changes every 3750 miles) - you can add any oil really (does not have to be synthetic). This low usage, by the way, is an outstanding result for this engine ... most other people seem to be adding a lot more. I think my original engine break-in procedures were good!
Z
