I can only imagine the picture, of course the valves are off!! even the head is off so no worry on falling things into the pistons.Anyway, if there a SOHC writeup, I try to find it. I was just looking for something like this but for a DOHC.When you say "use the small section" you mean where I put the ratchet, not the socket, right?KATwo40 wrote:Not to insult, but you do know that you install these with the valves out, right?
Absolutely - some were metal (intake IIRC) and the others (exhaust) were a plastic type material. I switched them accidentally and had the same problem. 10 to 1 you have the wrong parts.pr240sx wrote:All my seals are the same.The SOHC uses different seals for intake and exhaust?
I am using a set that came with my gasket kit.
