Valve stem extensions?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I have a set of wheels I got from japan, and they came with metal valve stems (they are fastend with a nut on the inside of the rims with rubber washers on either side). The front valve stems are crazy short, enough that I cant get my tire pressure gauge or air compressor on the valves because they are unflexible and so damn close to the rim. Now, I dont feel like paying $30 to have my tires taken off and put back on so I can have the front valve stems replaced with generic rubber ones. Anyone know of a place that sells valve stem extensions? something that could just screw on when I want to check tire pressure or fill them up...
240marcuSX
Car: E34 525i
E46 M3
do you think that its possible to just take the valves out and put regular ones in? just the valves not the entire stem.
Onizuka
I would have to take off the tires to replace the valve stems.
SmithSR
Car: 240sx
Have you asked the local tire shop? We have countless miniature extensions.
240marcuSX
Car: E34 525i
E46 M3
i meant the valve cores, not the whole stem.
Onizuka
The valve is threaded inside the stem. I dont see how changing this would make any difference at all, the stem is still way too short.
I will try a tire shop tommorow
skylndrftr
Car: 07 Nissan Versa S
2010 Ariel Atom (pending...)
i work at uhaul and what you request does exist, however i don't know where to get them...we use them to easily check tire pressures on the inside of rear dual wheels
240marcuSX
Car: E34 525i
E46 M3
oh, ok, i get what your saying, i wonder why the make them that short?
Onizuka
Picked up a set today, SWEET. Thanks for the help guys
