Valve spring compressor
240FeVeR
Car: 1992 240sx Coupe!
Hi guys,
While I'm not a newbie at most other aspects of the car, I don't know much about the internals, only because I have yet to dig in and learn.
My question to you more experienced members is what sort of valve spring compressor do you reccomend? preferably one that you've personally used.
I ask because I have a spare ka24e head, and I would like to begin a full build up immediately. I have already found valves and springs and retainers, I just need to know how I should go about removing the old items. As soon as I can remove all these items, I will begin the porting and polishing, then install all new items including a reground camshaft.
Thank you for any help.
float_6969
A "C" clamp style is what is reccommended in the FSM (factory service manual). I think that because of the way that the head is designed it would be difficult to use another kind.
robertwb70
Car: 72 datsun truck=PL-521/on 85 frame Z-24eng+cam+ported+weber38DGAS
JUST STARTED DIS-ASSEMBLY ON KA-24DE-HOW DO YOU GET THE SPRINGS COMPRESSED IN THOSE HOLES? I HAVE 3 DIFFERENT COMPRESSORS-NONE OF WHICH LOOK LIKE THEY WILL EVEN COME CLOSE TO DOING THIS JOB
ANYONE KNOW OF ONE THAT WORKS?WHAT KIND?WHERE?PICTURES?
Open4Cycle
You can add a short piece of pipe to the screw end of one of your existing compresors. You have to cut a slot or some sort of hole in the side of the pipe to get the keepers out.
sil80drifter
Car: 1990 240SX Hatch
C-clamp style comrpessor works well on ALL KA heads.
sil80
