WDRacing wrote:Which would you prefer and why. The BoostDesigns combo for $350http://boostdesigns.com/store/...id=65
Or the KA24DE.COM combo for $459http://
www.ka24de.com/
I'm going to be using the V3 Cams. So I'll need a very good Spring setup.
I guess it depends HOW stiff those springs need to be to work well with V3 cams...I'd contact the manufacturer of the cams and ask what would be better suited...96 lbs or 75 lbs @ ~34 mm...If the 75 lbs work well, I'd go with them over the 96 lb ones, which seem a little overkill and would just cause a greater amount of friction and wear compared to the 75 lb ones.
Are you also getting oversized valves to complement the stiffer springs and aggressive cams?
